treekiller
- Mar 10, 2007
Grimm - did you get a "kit" for the wheels in the middle of the track??
Groomerdriver
Put an M10 in...you'll never have to worry about hyfax wear again.
Budweiser
3413 miles on mine with some left. Wore quick to 500 miles and then just stopped wearing. I will replace them this summer though.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
treekiller said:Grimm - did you get a "kit" for the wheels in the middle of the track??
No, I didn't buy a kit. I made my own with a set of skidoo wheel supports and affixing them to the rails with the new wheels.
1900km so far, under a lot of low snow conditions, and still minimal wear. It looks like I won't have to swap the sliders out for next season!
Addict
Grimm, do you have any Doo part numbers for the mounts??
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
As I have an old 96 Skidoo, I dry fitted the part to see if it would work and it did. Here's a link to the part (#32 in the pic) I ordered:
http://216.37.204.206/wps/Skido
EM/Sk ... A=199&B=26
I think it's a little overpriced, I believe I paid $25 a piece. Maybe the newer Skidoo supports will work and maybe they're cheaper, I don't know.
ReX
Addict,
Yamaha also sells an OEM wheel kit that mounts in the same location as Grimm's. Check the on-line fische (parts at the top of the page) for your sled and you should see them with a dotted line around and the letters "AP".
They are expensive, but you can order all of the parts right from Yamaha and its a direct bolt in installation (holes are already there). To save a fair bit of money you can substitute the mounting blocks from a sled with a monoshock. I think they are identical.
The only downside to Yamaha's kit is it is set up for the narrow idlers so if you want to run 04 RX-1, Skidoo or Polaris wheels you will need to machine 0.060" off the mounting surface.
Addict
Thanks Grimm and Rex.Looks like I have another summer upgrade to do.
I too, use some Doo supports. Not only i paid only 5 bucks a piece but also have two support point. That is, you use upper stock hole then drill the bottom one yourself. Must admit, i had to enlarge the groove by a bit with a grinder. .. and yes, it is sized for 6205 baller. Part# is 503190389
... idle wheel support for GSX 2005.
http://www.motoneigeauquebec.com/forum/album_pic.php?pic_id=3716
http://www.motoneigeauquebec.com/forum/album_pic.php?pic_id=3717
wannagofast
too soon
I have 1820 miles on my vector this year on original set of slides and only half worn out. I think people are changing them too soon. Mine wore a lot in first 500 miles and have not worn much since. I think I can get another season out of mine.
Addict
thanks aVenture!
guyzoun
- Feb 3, 2006
I think that is the way: be patient.
On my new Nytro 2007, I did change them at 500 miles 'cause they were thin and I was on the go for a 1800 miles trip.
With the new sets of hifax I have rode 2500 miles so far and they are still good.
mork110
I have a 2005 vector and have just over 6000 miles and still have over 1/8 " of wear to get to the wear line on the sliders
