ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I have a line on a smashed up 2010 MTX 162 SE that was purchased from an insurance company by a wrecking company. I spoke to the wrecker on Friday and he said he would get back to me on price. The damage is:
broken primary clutch
broken a arms/spindle on clutch side
bent bulkhead/subframe/front bumper
the plastics seem ok
handlebars bent
no top part of cab on sled at all
That's pretty much the damage on the outside while quickly looking at the sled. The left side of the machine is toast.
According to the Yamaha mechanic crank runout is 10 thousandths (not sure if that is acceptable tolerance). Crank could be bent since the pieces of primary are broken off. The tunnel/skid/track appears to be fine.
The sled was written off and I am thinking about buying the sled and turning it into a project. If I get it for a decent price, then fix it up, I sell my 08.
How much is this sled worth? There are approximately 1500 kilometres on the motor.
Any insight would be greatly appreciated.
handlebars bent
hugger70mtnmax
That is probably harder for us to say than even you. If it has damaged the engine it probably isn't worth more than parting out the salvageable pieces. Even if the motor is good you would probably still spend at least 1500 scrounging up used parts. Maybe you should work out a deal to see if there is any motor damage before purchase.
swelly
- Feb 2, 2009
- Anchorage/Seward, AK
- www.swelltimecharters.com
Or stick your engine into it.
Mountaintech
The shaft the primary clutch bolts onto is not the end of the crankshaft. The two are connected via a splined coupling.
Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
Or Buy New
I just bought a brand new 2010 with a years warranty for $9500..........
