how tall of lug can I use?
sxr1000
minot ND
Hi,I have a 2006 apex GT and want to get rid of the risaw track for a taller lug, how tall can I go without studs? I am thinking of a camoplast cobra, any input? thanks.
Depends on how much work you wanna do>
I have an 06 Attak w/ a 1.5" lug only had to remove the tunnel protectors. The track would rub. Could have rode it, just did not like the vibration.
Drop a tooth in in the drivers and you could go crazy.......... Then some regearing would be needed.
I thought I saw on here awhile back, someone went with a 1.75 on there sled. You would have to go with 8t drivers for sure. Like Sob, I run a 1.5 on my Attak, had to remove the protectors as well and the track JUST clears the front cooler protectors. Or maybe notch the track?
Try a search, I'm sure you'll be reading for awhile.
Is possible to use the new Cobra track (1.352), with 9 tooth drivers and without removing the tunnel protectors? This would be without studs of course.
track clearance
i just installed the corba 1.325 track and 9 tooth ext. drivers, looking at the front heat exchangers guides looks close but i think it will work jeff
track
fast did you loose much top end speed, i run alot of hard pack hopeing the corba doesnt slow me down to much. I see you are running a 1.50 that baby really hooks thanks jeff
I had a 1.5 Intense and it rubbed a little either trim the track or just run it. Next step is to pull the protectors
I have a 1.5 x 136 in my 2007 rtx with tunnel protectors in , no problem !
