You're not going to get much from the mono skid. I would take some air out of front shocks. If you're trying to relieve the darting and make it easier to steer, I would try the woody dooly carbides. The mono skid does not have separate front arm pressure obviously. Transfer rod and limiter strap only affect transfer, not ski pressure. Maybe I should restate that. The limiter strap would add ski pressure if you tightened it. If it is loose already, nothing you do in the rear would take off ski pressure if your not under full throttle making it transfer. Make sense?
