sifty
Okay I've put on about 700 miles on my Attack and never bothered setting the clock. I always have cell phone with for the time. This last weekend rode in the UP around Lake Goegibic and cell phone kept changing between central and eastern time zone. If shoot-out had gone down I would have missed race because I didn't know what time it was. So How do I set time on clock on the sled?
snomonut
Would I be out of place to suggest the Owners Manual?? Which is where I would have to go to find the answer for you!
it is definately in the owners manual. Also tells you how to adjust light (brightness) in gauges.
Skydog
bjniceguy said:it is definately in the owners manual. Also tells you how to adjust light (brightness) in gauges.
You can change that!!! MAN YOU GUYS ARE SPOILED!!
Sled Head :-Þ
- Jan 25, 2006
Instructions are for smart people
When all else fails... read the directions
yamaslob
Hold the select and reset until the hr light flashes then use the select button to set it then hit the select and reset again to get mins and repeat i believe.
sifty
Thanks for the answer to my question. Only took five people to get an answer that I needed. My sled is here and all my literature on the sled is not. Will give it a shot yamahaslob thanks for the info.
