markowinnipeg
Trying to straighten my once again bent bulkhead but cannot get it to come back. Try'd the pry bar no go, hook straps to my come along then to truck and telephone pole and was able to get it with were bends in plate are maybe under 1/4 inch then starting breaking straps.
Then hooked to telephone pole and went in reverse, bent the hook on my heavy strap straight.
Any ideas on how to bring it back so I can remove and weld in gussets or is it a lost cause and time to anti up for a new one?
Thanks for any help
Thanks for any help
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Just going to have to sack up for a new one if you want it straight again. Usually can only get bent ones bent back so much and by the techniques you tried, probably give up on that one. Sorry brother, had to do the same this summer.
mattyg1405
i just spent no joke about 6 hours total on mine... i tied the sled back to a beam in my metal shop then used a double pull comealong and got it back "close to straight, its still out an 1/8th of an inch but i could live with that , then i welded in the gussets and called it a day...
cut the factory bottom plate/gusset out with a cutting wheel then it will move more easily...
you dont want to be jerking those stock a arm bushings , i actually installed ulmers bushings then straightened it out.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
If you absolutely need to use your original I suggest you pull it and use a welding torch on it and "massage vigorously" with some type of jig or coyote stretcher. It will give you the opportunity to gusset it and get her powder coated if you go that route.
markowinnipeg
Thinking will put it thought insurance, just with the 500 dedecutible and time wasted with entire insurance process if I could fix for same amount and get a reinforced one would go that route
Cherry08
Have you tried Tony Pinter........ he is in winnipeg and deals with used parts as well can get OEM parts.
markowinnipeg
No never heard of him? Do you have a contact number you can PM me?
Cherry08
ok i sent u a pm
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
cutting out the center support plate makes straightening it out easier. Then do yourself a favour and PM Grizztracks and get a kit from him to weld in and make it stronger than any new one.
I did that this summer and didn't bent it at all when I hit a rock hard this year.
09nytro
Yes grizz kit works .... But how i keep bending my upper a-arm ....
