Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Recently bought a hurricane flash tool. I have had serious difficulty getting any satisfaction. To start, it took about 30 tries to update the firmware. Error after error. Tried several cords, every USB port on the computer and finally got the firmware updated message. I was able to hook my phone to the flasher when it was powered by the computer USB. It downloaded a few files. I then brought the flasher to the garage and hooked it to the sled. Ends up with the same error everytime. Tool does not respond. I’ve tried two different phones, deleted and reinstalled the app several times, restarted my phone a handful of times, charged the sled battery to full. All ending up with that same message, tool does not respond. I’ve talked to Hurricane. I tried everything they suggested. I’ve messaged GAP innovations through this site. They haven’t answered yet. I’m about at my wits end. Any suggestions would be appreciated or at least a nudge in the right direction to solve this issue would be welcomed.
When you plug it into the sled does the indicator light come on, on the flasher? Does it pair with the phone without issue on Bluetooth? Have you logged into your account on your phone? The only time I have trouble is after pushing updates to the flasher and then having poor internet access on my phone while at the sled trying to retrieve the changes in the phone or iPad
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Yes. Indicator light is white, phone shows up in Bluetooth list as connected and yes logged in.When you plug it into the sled does the indicator light come on, on the flasher? Does it pair with the phone without issue on Bluetooth? Have you logged into your account on your phone?
White indicator light hmmmm. Dunno if the newer flasher has I different color light? Mine is red when connected. Anyway...... If it's paired and connected what screen do you see on your phone? Can't you post a pic of the error screen?
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
It's this with the sled running or keyed on?
Also would like to see the screen shot of the phone when you have the GAP app open on your phone
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Key in the on position. Voltage shows 12.2 on dash.
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
One other thing....have you uninstalled the gap software on the computer and tried it after a reinstall?
What error occurs when you hit the connect button on that screen?
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
At least 3 times.One other thing....have you uninstalled the gap software on the computer and tried it after a reinstall?
I'm not sure if this matters anymore, but if I recall early on the PC version of the install to the flasher was a little more trouble free
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Says gathering info, seems normal. Then the tool does not respond screen.What error occurs when you hit the connect button on that screen?
