jw440/800
I plan on trying to shave some weight tomorrow and see what that does with the 8bu10 weights.
Love the kit just need to get the little things taken care of.
shadow44
Keep this in mind...1 gram of weight is worth 200 rpm...roughly. Try running the tips empty, not really an issue to run this kit in the 9000-9100 area.
That sounds like a trail killer there. DNR would have a field day with that sled in MI.
mach9
It's only knarly when you use it FTW WOT. Otherwise when crusing or rolling through coaster trails it's quite civilized.
shadow44
bottlerocket said:That sounds like a trail killer there. DNR would have a field day with that sled in MI.
No louder than anything else on the market....I will get DB readings tomorrow hopefully. I tested mine at idle today ( 20" with a db reducer ) and it was 77-78db's, I was standing about 10' away.
I would also suggest that a cell phone vid isn't the best to go by
