Hyper chip---any one tried it?
iahacker
Boone, Iowa
Anyone buying this must believe in santa also,,,,
Some ex.
q: "WILL YOUR CHIP ELIMINATE MY RPM GOVERNOR OR INCREASE MY TOP SPEED?"
a: "FOR MOST ELECTRONIC GOVERNORS OUR CHIP WILL HAVE NO EFFECT ON TOP RPM OR SPEED"
I thought it would make hp, here they tell you it doesent.
one more
q: "WHAT TYPE OF MODS OR CLUTCH WORK NEEDS TO BE DONE TO USE YOUR MODULE?"
a: "NOTHING IS REQUIRED OF YOUR MACHINE TO INSTALL AND USE THE GENESIS PERFORMANCE MODULE, ITS A SIMPLE PLUG AND PLAY OPERATION THAT REQUIRES NO CLUTCH WORK OR MODS OF ANYKIND TO BE UP AND RUNNING, OUR MODULES ARE SELF ADJUSTING AND REQUIRE NO TUNING TO WORK"
Again, no clutching needed = no power gained.
I wouldn't install it even if someone gave it to me.
What a bogus!
BINGO!!!! This applies to ANY aftermarket performance product!
You guys crack me up :jump:
Looked like to good to be true for 30 bucks. Was just curious if anyone tried it.
Thanks for the relpies.
Looks like the same one they sell for cars. Open it up and all there is a a resistor! A box with only two wires.... come on!
does it make the handwarmers hotter? looks like a scam what does it on the GSX streetbikes then?
