I need bushing instructions
anything fast
Canada
2007 apex 1000
Hey I got a package of SPX metal bushing for the front of my apex but there are no instructions. I need to find some instructions on which bushings go where there are apporimately 24 bushings
My only question is how do I identify what bushings go where, here is a picture of the 28 bushings they don't have any identifying information on the individual bags
They only go in 1 way. When removing your stock bushings, just match them up diameter and depth. That's how I do it.
I bought the same kit and had a lot of left over bushings. I had no idea where the biggest ones went, it was confusing but just take your time and match them up as previously mentioned.
as others mentioned just match them up. kit does multiple years so you will have a couple leftover, i also had the 2 larger ones left, so i assume those went on the earlier chassis at the bottom of the spindle/ski post. i used a piece of threaded rod with washers to press them in where and if i needed too.
The 4 larger ones go in the spindles to snug up the spindle shaft. If your spindle shaft isnt perfectly straight, it will make your steering super stiff. They are less likely worn if you've greased your spindles regularly.
I figured those four big ones went into the spindles I will probably replace them too just so I'm sure everything is new and tight
