Bushing help.
slimjim2525
Windsor Locks, CT
Got my sled out of storage and started doing the bushings. Got oilites from ulmer. Just a quick question. On the bulkhead side where the motor is, can you put the bushing in from the front? It's awefully tight going from the back with the motor there and all. On the upper one I had enough thread showing to get the nut on then just screwed the bushing into place, but on the lower one, there are not enought threads showing. So either I have to get a long piece of threaded rod to press the bushing in, or just put in from the front which would be much easier. Thanks.
OK great, you just saved me a whole lot of grief, and a trip to the hardware store. Wonder why they didn't put them in from the front from the factory?
