idle rpm's at 750
yamamarc
Massey Ontario
Canada
2019 zr9000 Ltd
Took my wife's sled for a run to make sure everything is running good, I started it in the garage, waited for it it warm up then reversed it out to the driveway.(was running fine) Once I switched to the forward position the rpm's dropped to 750ish and was hearing a light ticking (sounds a solenoid) When I reved it up had a belt sqweal then I shut the sled off and restarted it and it was fine? Any ideas what happened?
Will spark plugs cause this?
it is still the fuel from last season (91oct with stabilizer)
Just seeing if someone has experienced this
thanks
Marc
It didn't go fully into gear. What you heard was the actuator cycling it in. That's why I cringe when guys switch gears and then pin throttle. You did good.
You might want to change the gas.
