Idler bearings
Canadian Lad
Ontario Canada
I noticed a couple of the bearings on my 06 vector are starting to go today. Are these bearings replaceable or do you have to replace the entire idler. Also also anyone know if the innner and outer ones are the same and what the number(s) are.
I know that the after market colored wheels are replaceable... But sorry to say the stock black ones are non-replaceable..Not sure about the inside ones.. Never had them off...I put the colored ones on right away.. I still have two new black ones that were never used..My bearings on the red ones have 4,000 miles now without a problem... MM.
Have you lifted the back end up and turned the wheels to see how they feel and sound??? MM.
No but I plan on pulling the skid in another momth as by then most our my riding will be done. They were OK in the fall and I have only put on about 700 miles this year (bad yea for me) I am hoping to make it through until then as I do not have a heated area to work and everything is covered in snow and ice. Wind chill today for example is -28 C.
On our 06 Rages the only wheels with replaceable bearings were the 2 that hold the track up and the middle one of the three larger ones in the rear.
