Liquid Blue
Question on inner idler wheel mounting (OEM). Can I mount facing either direction (left or right)? Basically, is the bearing centered in the wheel, or will there be some offset to either side? I have an '07 RTX, but I am assuming a GT or ER would be similar. Thanks
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
I believe that every wheel on these sleds have the bearings centred and the face of the idlers is the same on both sides.
you can mount them either way as the bearing is centered in the wheel.
ebockus
I mount them so if the clip ever comes out the wheel won't fall off. so clip facing out. also grab some polaris wheels for the 4 small outter wheels. great little mod to help with slider wear. i also run du pont s
Liquid Blue
Thanks!
ebockus
Glad to help. the slowaris wheels are a touch larger which helps with slider wear. just watch your rails don't develop a crack with the extra forces applied. mine have been fine so far.
There is a write up about the Polaris wheel mod. Did it to my Attak. Sliders lasted well over 3k miles.
http://www.ty4stroke.com/threads/idler-wheels-2-bolt-mounts-mono-skid-fixes-pics.78847/
