What is the idler wheel torque spec for 2009 Vector and 2011 Apex? I just stripped a nut that is welded onto the back of a bracket on the Vector and it is $39.00 Cdn and looks like a real bear to re-install as there are 3 bolts, bushings, collars and a grease fitting that run through it as well as shock tension.
