idler wheel torque spec?
vice108
Maine
What is the torque spec when installing idler wheels on the monoshock skid? Also - does it require blue lock-tight?
Vice108,
I'm not sure if the Proaction skid wheel torque specs are the same, but I'd assume they would be. I'll get them for you tomorrow. Be real careful, though. I've stripped many of those when putting the wheels back on; both the threads on the nut and the bolt. I'm fairly good with a torque wrench, but those buggers seem to get to a point and simply strip. You'll definitely want to step up the torque settings until you reach the proper amount.
Jon
All idlers (except the back) are 52 ft. lbs. (Pro Action). I can only assume it would be the same on the Mono, but hopefully someone could chime in to verify. Also, no loctite is require on these wheels.
Jon
Jon
Thanks ecopter.
Someone out there must have access to the Apex or RX1 shop manual with the mono specs ?????
