What is the difference between low and high resistance fuel injectors? I need bigger injectors in my sc apex and am not sure which one i need. Thanks in advance for any help.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
we will size your stock injectors to any size up to 700cc
Do what Dave suggested, it works good (not as expensive either). We had Apex injectors resized by him & they worked flawless.
Is that enough cc to run 30-34lbs of boost? I was told 1000cc. Just want to get it right the first time. Not doubting Dave at all he is extremely knowlegable with top notch service.HURRICANE said:we will size your stock injectors to any size up to 700cc
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Actually with that boost,you will need 1000cc injectors.We have new high impedence injectors available for $150 each
Are these plug n play installation or will i need to mod the fuel rail or wiring harness?HURRICANE said:Actually with that boost,you will need 1000cc injectors.We have new high impedence injectors available for $150 each
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Chris,you should give me a call.The injectors fit well with a spacer and a wire adaption but there are other fuel rail mods that you will need to insure fuel delivery for your potential HP.
