powercomader 5 with bigger injectors?
quadsean1
Brighton, Michigan
Has anyone here ran a powercomader 5 with bigger fuel injectors? If so how big in cc's can you go before it starts to mess with idle and low end performance? How many lbs of boost can you run with larger injectors? Looking to put bigger injectors on my sled to turn up the boost this season. I'm at sea level also.
you can go to about 550cc injectors while tuning with PCV.Bigger injectors create a rough idle and much bigger injectors create a hard starting issue with a piggy back controller.This limits your hp to just under 400hp.These are the reasons why we have our Hurricane secondary injection kit.Then there is ample fuel for big hp
