Installing Studs on Predrilled Camoplast Rip Saw Track
dpcrxone
Winchendon, Massachusetts
I have a question. I am installing Woody's 8mm Mega-Bites on my new Camoplast Rip-Saw Track and have found a problem. :shock: I bought backing plates for each stud and I am unable to install 96 of the studs because the pre-drilled holes are located to close together for the plates that I bought. I have looked at the pattern and it appears that if I purchase the Woody's dual Backers I will be able to install the other 96 studs. I do not have any measurements to verify this but it looks like it will work.. Has anyone else ever found this problem and will purchasing the dual backer plates fix the issue. :( I am leaving for a weekend ride with my brothers and our wives on next Thursday and must find a solution and purchase the material and install before this date.. Any help from this forum will be greatly appricated :D
That stud pattern was designed by woodys, so if you use woodys double digger backers they will fit perfectly.
Hey Redliner and Daveyboy. Thanks for the info. I have ordered the dual backers and am trying to get them overnight shipped so I have time to install. This is a great site and thank again for all your help... :D :D :D
