Interchangable RX1 Apex parts.
mikystyle
NH
Just wondering what parts of an Apex would fit on an Rx1 with little to no modification.
The seat takes cutting the gas tank cowl is is probably the best mod.
The front end will fit if you swap the entire thing, a arms, steering rods, shocks, spindles
Rear suspension will work but you will need to fab mount plates
Thats the big things to me.
Lets not forget the motor ! There is very little defference between the chasis of the two except the stearing post frame loop, the gas tank and the body work.
Yes there is difference in the A arms, spindles and the steering linkage...... but you can swap entire systems or groups from one to the other. I put everything from an Apex onto an 03 including the fuel injected motor,electrical system, seat, bars and front end. The biggest trouble I had was the fuel pump in the gas tank.
I have made several clamp rings but still have a bit of leakage through the bolt holes. I just try not to let anyone smoke around it. LaLaLa
