Who is the Lightest ? List the weights on Powder Lities, McXpress, MPI, CPR...... I would assume the supercharge has the most front end nose weight because everything is mounted in front of the engine in the nose , unless there intercooler is light weight. , could there be as much as 4 to 8lbs. difference in some of these intercoolers. Looking for the total package. best performance, hassel free, reliabile, light weight, no heat problems, no header problems, just flat a$$ works the frist time every time. Thinking about running 15lbs boost, 100-th-head gasket for 9.11 to 1 ratio, 4 degree retard timing key.06 APEX MTN.
Turbo Tim
I had the lightest intercooler that bender makes on one of my sleds , it endedup cracking out out at the seams . I called Bender , and they said they had a thicker one which is what I have now. Moral of the story - Don't get a thin intercooler to save a couple pounds.Boost It said:Who is the Lightest ? List the weights on Powder Lities, McXpress, MPI, CPR...... I would assume the supercharge has the most front end nose weight because everything is mounted in front of the engine in the nose , unless there intercooler is light weight. , could there be as much as 4 to 8lbs. difference in some of these intercoolers. Looking for the total package. best performance, hassel free, reliabile, light weight, no heat problems, no header problems, just flat a$$ works the frist time every time. Thinking about running 15lbs boost, 100-th-head gasket for 9.11 to 1 ratio, 4 degree retard timing key.06 APEX MTN.
I hear Ya Turbo Tim, No one wants to buy the lightest just for the sake of being light, I'm sure of all the 4 to 5 top turbo kit builders will claim to be the toughest, of those 5 who is the lightest without sacrificeing durability currently being built. Brand X might be a better design than Brand Y . They are to costly to make a mistake.
peteracing
If you want a reliable and lightweight aftercooler, you should go with
the powderlites one. it is a simple ,straight thru unit and performs ...
What i dislike about the bender one is core area...I dont have it's airflow
specs but,it "looks" less efficient?... I is a straight thru desing tho...
Thanks for your imput peteracing. I ran into a local friend that bought brand Y intercooler turbo kit , and after seeing Powder Lities intercooler in person he wishes he would have bought Powder lities instead of brand Y.
powderlites
Intercooler weight!!
Never heard of Intercooler trouble yet! and Yes it is light and yet very large flow and cooling on our's
http://www.powderlites.com/turbokits.html
