Intermittent No Start.
MxzKing
I bought a 08 RTX as a second sled. I've had a couple issues that I have resolved using info from here now a new issue has showed up. When I start it sometimes I get just a click and then it will fire other times it starts no issue at all. Is this a starter issue or are there some key ignition issues with these sleds.
More than likely it's the starter solenoid that's on its way out. Easy way to check is to short across the two large terminals to engage the starter.
I took it to the dealer this morning they are going to do the wire harness recall hopefully that will fix the issue.
