DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Has anyone mounted their iPhone above the stock gauges? I'm trying to figure out how to do it but would like to see what others have done.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Rockerdan mounted his to riser looks good he has it on his buildHas anyone mounted their iPhone above the stock gauges? I'm trying to figure out how to do it but would like to see what others have done.
DMCTurbo
- Nov 12, 2005
Yes but I'd rather have it where I can see it.Rockerdan mounted his to riser looks good he has it on his build
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Ive been radaring/speed running for a long long time....the critical info below riser is best ive ever had now.Yes but I'd rather have it where I can see it.
Before when tucked, i would always need to look from under left grip, and try to see gauges.
Now when tucked, my iPhone is right there, and I can adjust it off the left with ram ball mount.
Putting an iPhone up above the gauges is not a good spot at all. For that far away you need iPad.
Dan
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
I put mine in an aqua box on a ram mount above gauges. Works ok...but touch screen doesn’t work through garmin aqua box. I usually just keep it in my pocket and check logs when testing. When trail riding, looking at boost and afr not really that important to me. BUT I am thinking about ordering the case rocker Dan used..if I could actually use the touch screen I may keep it up there as I also run the rider x trail map app.Yes but I'd rather have it where I can see it.
DMCTurbo
- Nov 12, 2005
I have the handlebar mount and I just can't see it well enough. I've wedged my iPhone above my gauges and it's perfect for me but hit a bump and she goes flying lol so for me I prefer it to be in my line of site.Ive been radaring/speed running for a long long time....the critical info below riser is best ive ever had now.
Dan
DMCTurbo
- Nov 12, 2005
Do u have any pics?I put mine in an aqua box on a ram mount above gauges. Works ok...but touch screen doesn’t work through garmin aqua box. I usually just keep it in my pocket and check logs when testing. When trail riding, looking at boost and afr not really that important to me. BUT I am thinking about ordering the case rocker Dan used..if I could actually use the touch screen I may keep it up there as I also run the rider x trail map app.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
actionjack
- Apr 9, 2005
DMCTurbo
- Nov 12, 2005
How is it mounted? I have a similar case.
actionjack
- Apr 9, 2005
Ram 1” ball diamond plates and short arm. I 3D printed the Arkon adapter but Dan has a link to one in his build thread.How is it mounted? I have a similar case.
APRM2T
https://www.amazon.com/ARKON-T-Tab-...=2025&creative=165953&creativeASIN=B01MXQQWF3
Where you mount your screens is quite subjective. I experiment with this at least every other year. I have my Garmin on the bars and I don't think I would want it above my gauge. I mounted the Arkon case there because I considered this supplemental gauge info related to my tune and data logging. It turns out the iMotoneige app is much easier to quickly get distances and routes when trail riding in Quebec so I spent a lot of relying on the iPhone X over the Garmin but used the Garmin's trip computer info.
I had planned to use my old iPhone 6 plus but it wouldn't cooperate so I threw my new X in there and it worked perfectly except I go ZERO data logs from my flasher. The 6Plus was a struggle to zip the case up too. Back in the drawer for it.
actionjack
- Apr 9, 2005
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Ram/Aquabox combo. Have a taller windshield that covers it all now.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
How did ya mont the camera mans orange chair to the front bumper
4kops
one stop is back in operation they have a mount for a viper that will work on a sidewinder they make it for a power commander display mount.
- 8K
