ruffryder
Has anyone bought one yet? I not interested in the auto tune, but the PCV comes with ignition and fuel adjustments for about the same price as the old PCIII, which only does fuel.
I see that the dynojet website lists that they have the PCV for the 2010 nytro's. Just curious if anyone has one yet.
shadow44
I have one sitting in my garage..got it at the end of this season...says it's for an 09 but from what I understand the part number should fit all years..if not I've still got my RB3.
ruffryder
interesting, yah, it shows the PCV is for 09 and 2010 versions.
Good catch. Where did you get a map for it?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The PCV only adjusts the fuel curve. You currently can not adjust the timing curve. There will be an "Ignition Module" for the PCV just like there was for the PCIII as well.
ruffryder
really? dang, that sucks.. Oh well. Thanks for the information!
yamahaboy701
Bought one of the first PCV for my 2008 Nytro last summer. Had to update it a few times and then it worked great. Was lots of hype last fall about using the PCV and autotune with a turbo but not sure if anybody tried it or got it to work like everybody hoped. Have seen a few on SC sleds though...
shadow44
Srxspec said:The PCV only adjusts the fuel curve. You currently can not adjust the timing curve. There will be an "Ignition Module" for the PCV just like there was for the PCIII as well.
Will the PCV fit all years? were you able to do any teesting with it and the auto tune?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Have used the PCV and autotune stock, full exhaust, and turbocharged. The autotune is nice, but I believe it to be more handy for the guy making maps than a guy who is an average trail rider.
mtdream
So, Allen, do you have a map for my turbo for the PCV?
I am still nervous about the Pure Logic boxes...
towerrigger
So for a guy that is doing exhaust and intake, is the PCV a waste of cash? Is it best suited for a turbo setup?
