ArcticWhite
- Sep 25, 2007
The stock sway bar kit is pretty hard to remove. I ride my sled mountains and prairies. I'd like to be able to take the sway bar off and on easily. Does anyone make an aftermarket one designed for easy install and removal?
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
I've been playing around with different ideas to easily detach the sway bar.
I am currently thinking of removing the bolt that holds the endlink to the a-arms and instead use a hitch pin style set-up on both sides. Then make some sort of a clip to hold the sway bar up and out of the way when detached from the a-arms.
