sway bar for 03 rx1
stomper
Saskatchewan, Canada
Would a sway bar, bushings and links from a 06 nytro fit an 03 rx1. There is a guy localy that has a set for $25 and says they are a good upgrade for the 03 rx1. Also what diameter would the sway bar be.
They should fit, its a huge improvment over stock if the bar is a 13mm? Even if it's not a 13 that's a good price for just the links. I think your stock bar is 10mm stock for the Nytro is 11mm.
