olivia317
- Jan 20, 2013
- Olivia, MN
- 2012 FX Nytro XTX SC
Doing some test n tune on the RX1 yesterday. Running 108-110 in 1000’. Hooking up is a problem, changing studs should help. My question concerns the stock primary. Is there more there or is this it. Running Hauck VP weights and spring. WOT rpms are 10,250 with a finishing climb to 10,500. Secondary is set at 3 and 3(60%) with the silver spring.
Secondary looks good as well as the primary. If you want the belt to climb higher in the primary you will need to have it cut for Overdrive. Then you will need to cut the helix pocket to prevent coil bind or run an aftermarket helix
