Is this the Pilot Ski Kit I want for the Apex?
I think that looks correct...they do make a wider version but most want the 5.7
just a suggestion here.....many of us found that the stock DOO carbides that come in kit arent so great.....so you might want to purchase the SKI BOTTOMS only...
you can grind off your LOOPS abit to fit,so you dont need loops....and I think you will just need the rubbers then....not sure about bolts,i cannot recal if you can use the yammie bolts or not.
but then you can buy yourself a nice set of SHAPER bars for these..which will make it RAIL!
Dan
Do you guys run the expedition, intense, or extreme carbides? I Would just like a 4" on the outside and 6" on the inside.
dont remember, intense rings a bell.
On this ski you have center and inner, the inner sits higher, but as you turn the inner touches the ground.
6" center, 4" inner is a very good place to start
Pilots
Just bought a slightly used RTX with older 5.7 pilots on it that needs carbides. I went to Stud Boy and they don't offer a 4" but have 4.5". Does anyone have part numbers for the 4 and 6 inch to make sure I get what I need?
