Attak-Firecat
Does anyone know for sure whether the top bearing on the inboard side of the chaincase gets greased? It appears that gear lube from the chaincase is doing the lubrication for this bearing, but the inside seal on the bearing seems like it would prevent gear lube from getting into the bearing. On disassembly, the bearing was clean with gear lube in it and no grease. Is this right? I'm paranoid that I'm going to lose that bearing. Thanks in advance.
