revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
Can anyone advise if the jackshaft bearing on the PTO side is pressed on? I fought with it tonight and it would not move so I'm thinking that is the case...
furg69
Nope it's not pressed on to my knowlegde. I believe it's supported with a retainer that unbolts from the chassis before you can remove it. Some bearings are a B@&%$ to remove.
revster
- Aug 18, 2004
- La Salle MB
furg69 said:Nope it's not pressed on to my knowlegde. I believe it's supported with a retainer that unbolts from the chassis before you can remove it. Some bearings are a B@&%$ to remove.
No sorry, not removing it from the sled, that is done. ...and the retaining clip is removed. The bearing won't budge from the shaft so I was thinking it was pressed on.
dubla92
Pressed on - remove jackshaft to replace bearing.
revster
- Aug 18, 2004
- La Salle MB
dubla92 said:Pressed on - remove jackshaft to replace bearing.
Yes it is out of the sled. It's pressed on for sure then eh?
toddt
Bearing
Ya i had to press it off and press on the new when i did it. later.
revster
- Aug 18, 2004
- La Salle MB
Alright thanks guys I'll take it somewhere and get it done tomorrow. Thanks
I just threw a little heat at mine and it slid right on. Just like replacing polaris crank bearings. haha
revster
- Aug 18, 2004
- La Salle MB
vip8 said:I just threw a little heat at mine and it slid right on. Just like replacing polaris crank bearings. haha
not mine. She had to be pressed off.
