2BLUE4U
This year will be my first year with a four stroke so I have some stupid questions.
1) Do most of you carry jumper cables?
2) Does Yamaha sell a set that is compact and would fit nicely in the trunk of the sled?
3) How often have you had needed a jump start?
4) At least one time a year I ride on a weekend when the temp doesn't get above -10 F and as low as -45 F (not wind chill, actual temp). Will I need to store the sled indoors to even have a chance at starting it the next morning?
5) Does it pay to buy the battery heater they sell?
SledFreak
- Feb 7, 2005
- Ontario. Canada
How does the battery heater work?
2BLUE4U
It's listed on Yamaha's website under accessory kits for any four stroke. It looks like a pad that sits under the battery the pre-warms it prior to turning it over.
http://www.yamaha-motor.com/sport/acces ... etail.aspx
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Many pasts last year of happy 4 strokers starting way below zero, ie 35+ below .
I don't have any personal experience but was pleasantly surprised by the many positive reports and will be buying an Attak as soon as I can.
Yamadoo
Yamadoo
2BLUE4U
I see they have the equivilant of a block heater for sale also, anyone install that?
tmk50
I carry a set with me, but have never had to use them. Coldest nights that I have left it out in were around -20 or -25 F.
It has always started up - obviously it cranks a little harder, but I have not had any problems getting it started.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
2BLUE4U said:1) Do most of you carry jumper cables? No
2) Does Yamaha sell a set that is compact and would fit nicely in the trunk of the sled? Yes, but not needed
3) How often have you had needed a jump start? Never
4) At least one time a year I ride on a weekend when the temp doesn't get above -10 F and as low as -45 F (not wind chill, actual temp). Will I need to store the sled indoors to even have a chance at starting it the next morning? No
5) Does it pay to buy the battery heater they sell? Save your money
Swiss Sledder
I have had to jump start my 03 RX-1 twice. First occasion it was 40C below and the second time it was 45C below. The day it was 45C below, we jump started some 2-stroke sleds and the propane tanks at the hotel were frozen. There was a Warrior on this trip with synthetic oil and it only had to be jump started when it was 45 below. In both situations, this was in the morning after the sleds sat outside all night. Riding during the day and stopping for lunch to warm up for a few hours in 38 below weather, the sled would start right up.
Now these were extreme conditions and it was before Yamaha introduced the semi-synthetic oil. Since I switched to the semi-synthetic I have had no need to use jumper cables. Personally, I don't see the need for jumper cables because when in these extreme conditions, you are always staying at a lodge where someone will have cables to jump you in the morning.
One guy with a turbo had the oil heater cable, but he rarely used it.
Fergie
I spent $7.00 @ radioshack, 5' of monstercable speaker wire & 4 alligator clips & I have never had to use them. rode many times in canada -40 no problems.
2BLUE4U
Thanks guys
rx-1erlimitededition
Personally, I think I would go for a block heater over the battery heater. If the block is even somewhat warm the whole engine turns over easy so the battery isn't taxed. Keeping the oil somewhat warm also prevents dry startups. Personally mine started at -25F which is as cold as it ever gets here and colder than I would ride.
SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
-40F and my brothers has a hard time starting. This is before the new oil. I have now put a block heater in it. Real easy to install.
Spend your money on a coolant hose heater. Easy install into the coolant hose and it keeps the entire motor very warm. Only cost about $35.00. Cold starts not an issues especially with the semi synthetic, but it sure is a lot easier on the motor with it plugged in.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
2BLUE4U said:This year will be my first year with a four stroke so I have some stupid questions.
Never have!
Yes I believe they do!
Never in 3,000 miles.
-45 is damn cold. Most two strokes have a hard time with those temps. Trick I used with my 1000 tripple two stroke was take the hair drier from the room and lay it on the pipes blowing on the jugs for twenty mins and presto easy starting. Two hairdriers was even better. I've seen two stroke guys pour hot water over the jugs (slowly and carefully so as not to wet all the electrics) where they had no hydro.
At -45 indoors would be way better on any sled.
For those temps I would want to warm up any motor if I could. A warm battery gives more cranking but the motor is a block of ice I would go with a inline engine heater for -45 below. Yami has one (aftermarket as well) dealer will install. Battery heater probably not needed. Synthetic oil or not thats hard cranking.
I've seen RX's start right down to -35F and colder on regular oil so semi synthetic or full synthetic should go even colder. I really have to question if this is a good thing for any motor when its that cold. My sled in -45! I'd want it plugged in. Hair driers (be carefull with them they can melt things) something or someway to warm it up before starting. IMHO
I know at -25 to -30 the RX starts fine. At -45 I don't want to ride anyway. I have but hey it just way to cold to be fun anymore. It starts to become a survival ordeal more than anything else. I've had the frostbite to prove it.
Tom-RX1
only had to jump start once at -42 my own fault did not put any gasline antifreeze in and it came out of a warm garage the night before . starter jets were froze up . trouble light under hood for 10-15 min quick boost fired right up . started it next day at - 43 . ( killed the battery trying to get it going with the jets froze ) 9,000 miles on sled now .
Tom-RX1
Tom-RX1
- 13K
- 8K
