JODY
My factory Ohlins# 000696-08/48 L 165 came on the machine stock 2006 Apex Gt
I ordred the 5.5kg spring from Yamaha GYT-8GD47-00
The Ohlins# 000696-11/54 L 465
Is that the correct Ohlins# for the 5.5kg spring? if not is that spring stronger?
Could someone please help me with these:
Just wondering if I did get a stronger spring because they are the same length and same wire diameter
Is it correct that the factory spring is 4.6 kg
Please help, want to make sure it is a stronger spring before I install it
I weight 230lbs without gear and i was told that the 5.5kg spring will not bottom out for me
