Just finished this years project. What do you think boys?
Ted Jannetty said:
Otis RX said:
Ted, thanks for the settings. Got the wide band fixed. Had a bad ground.
Can you throw me some A/F targets at few RPMs?
I'm at 12.3 @ 1500
12.0 @ 3000
12.1-12.2 @ 5300 clutch engagement
How tight do you run that track?
TIGHT LIKE A BANJO STRING.
A/F should be 14.5 at Idle, and up to just before engagement.
At this you are on the Pilot and fuel screw, so close the fuel screws about 1/2 turn and try it.
then when engaged, and driving light throttle should taper with throttle around 13.5 at light throttle and 12.0 at WOT.
Ted.
I tightened her up the other day and will review again this morning. Thanks for the a/f info. Looks like she a little fat right now. I have to check the pitot jet. I bet I left in the plugged jet from last year.
Thanks Ted. Talk to you soon.
Ross
Otis RX:
I would really like to see some pics of that vortech bypass valve installed before the pitot. This is on my summer to "do list"
