mattsapex
i to have the same issue, what is a rta and can i get the little rubber boot too.
Highmiler
switch
Years ago, I had the same problem with a switch I broke on my SRX. Found one in a Dennis Kirk snowmobile catalog. The red button was listed all by itself for $16. I thought too good to be true, however took the gamble and it was identical. Don't know if they still sell it, but worth a look. Hope this helps.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
RTA is the Yamaha service guys that your dealer calls to get help it sands for Regional Tencnical Adviser RTA have your dealer call them and they will shipp him as many as he needs there is not part number from them when i last worked for a dealer and went to the one day service school that what they told us to do its that simple on one else has them or you can buy the whole switch
jkenosh
my dealer replaced my switch for 8.00
ReX
The RTA having switches is good to know.
I also broke mine off last season. I took the switch assembly apart and glued it back together, but on my last ride I hooked my glove on it and snapped it off again.
I asked my dealer last season for a price on it and the switch is something crazy like $200. I'll call them again Monday and see if they can get just the plastic piece through the RTA.
Right now there is enough left that if I hammer down on the switch with my glove it will shut down. The problem is the only way I can get the sled started again is to install a screw into the plastic and pull it back up.
yamarog
if the switch is broke off with the button down, start the screw by itself, without the broke piece attached, then you just pull it up, in an emergency, or on the trail it can be ridden just fine like that
