Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
Anyone have any experience or know of anyone who has used these? Looks like they may work in a ripsaw track..
http://www.koldkutter.com/catalog/index.php
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Buddy of mine done his track lugs with small self tapping metal screws and my other buddy done is Camoplast tracks in his side by side with them to. Works greatAnyone have any experience or know of anyone who has used these? Looks like they may work in a ripsaw track..
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I would think that they will pull out easily on a sled track. They are made for bikes & quads running on glare ice. Sleds run on dirt, asphalt, concrete, rocks, stumps, etc. I would say don't waste your money. Just my $0.02
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
I know a guy that tried them in his ripsaw track and it did not work well at all... They tore out easy and then caused the track to tear at the lugs. Then it started to throw them out at higher speeds and put small dents all over his tunnel towards the rear. Plus it could poke a heat exchanger?
Dont do it ,they will RIP right out ! they only work good on thick boots and knobby tires ,
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I have good luck with Bergstrum Trail Grabbers In a Ripsaw track. You have to be careful which lug you install them in and make sure they are centered in the meat of the lug . Then I used some good Locktite super glue on the treads and installed them with a cordless drill and nut driver. let them cure over night and your good to go! I have about 5000 miles on these in my Vector LTX and they are holding up fine. These are not to take the place of Normal studs! They don't Penetrate like a carbide stud on ice . They will give you more control on ice and aide in stopping and turning. The good thing is the chance of having a tear out and major heat ex-changer damage is next to none.
NEW for 2015 - 1" Trail Grabbers
Keeps Your Snowmobile Under Control On Ice!
Ride Safer, Not Faster!
Advantages
Advantages
- Running on ice (flash video)
- 180 degree spin (flash video)
- The track is not nailed to the ground(flash video)
- Derby Track Test (flash video)
