Lake Effect Snow Bar Risers
DeepFrz
Duluth, MN
A few questions...
I plan on powder coating the stock bar black, and getting either a black or red 2.5" LES Pivot Bar. I've read in other threads that I will not need to extend the cables for this, is this correct?
Does any have a picture of a red bar riser on a red phazer? How close do the reds match?
I'm looking at adding the same riser and would like to see picture of it in different colours too. I'm was debating between red and silver.
that is corret you do not have to extend any cables. i have the chrome one on mine and all my cables are stock the only thing i had to do was keep the throttle cable out of the hooks that go down the the steerin post under the plastic other wise it would not turn complety to the left.
if you are going to powder coat your stock steering post then i would suggest that you just order a chrome one and have it powder coated at the same time so that way the colors match perfectly.
That's good to hear, I wasn't sure if those hooks were there for organization or for heating issues. I went with a red pivot bar and found a place locally to powder coat the post a flat black. It should look great on a red phazer.
cool glad tat it worked out for you take a pic when it is all done so we can see
