N87Turbo
- Nov 30, 2012
I have a 2012 XTX with the OFT relocator installed but still need to go higher (Im 6'4"). Looking at lakeffectsnow risers. I was told their 2.5" pivot riser will work without having to extend the brake/throttle lines, is that correct? Originally I was gonna do a 4" riser, what are people doing for the brake/throttle? (any kits available) Or will the 2.5" pivot be the best/easiest route? Sorry for the newb questions this is my first sled and Im already addicting to modding it!
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
you can go higher, you just need to reroute the cables, I have the rox riser adjustable, it goes over 2.5. I have the oft as well.
JP270NYTRO
Im 6'6" and i put a 4"and on my xtx and its perfect standing or sitting..
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
JP270NYTRO said:Im 6'6" and i put a 4"and on my xtx and its perfect standing or sitting..
John, you need a OFT relocator to correct the steering geometry, it's the best mod for Nytro.. I have an extra one kicking around if you want it.
Ffbsy
oft
What are you looking to get for the oft
NL-vector
I have the 2.5" Lake Effect riser and OFT relocator on my xtx, just re-route the throttle cable. Height is excellent! I'm 5'11" but I few of my buddies are taller and they say it feels good.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
if you go the taller route just order the mtx cables and lines (i believe they are 1 1/2" longer)
brs077
- Mar 8, 2005
- Cobleskill, NY
- 2013 Yamaha FX Nytro XTX 1.75
I've got the setup you're talking about on my xtx You need to reroute the throttle cable per Relocator instructions, and the parking brake line needs to be rerouted over the radiator instead of around it as is stock. I replaced my brake line too with a braided/extended cable from Schmidt Bros, since I was getting a clutch from them anyway.
I've posted pics, if you want to see how it all looks.
fxnytroxtx
Guest
Got 2.5" lake affect riser in blue for sale pm me if interested
mx1500
i have a 6" rsi riser with NO extensions what so ever. everything works fine for me.
