Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
What is the largest lug possible to install on a 08 nytro that has stock drivers (guessing 9 tooth) and tunnel protectors in place....
crazykid
Ive got a 1 1/2 lug track and it looks like the max, But that's at the front cooler protectors. I think you can go 1 3/4 if you remove the front protectors, im not sre though. There are some threads on this im sure.
TheKoning
2 inch is largest with no protectors and stock
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
2" with 9 tooth stock drivers?
TheKoning
100% yes with the stock drivers. Wether that is the biggest not sure, not sure if you can go even bigger than that... its possible i think to go bigger than 2" with different drivers. The answer is already on the forum tho im sure, use the search.
