4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I found the wiring schematic and it is a very simple circuit. From stud 1, there is one connection (c428) that goes to the rear trailer connector. If you have option YU2, there is also a cut wire that goes for a 5th wheel install. Check the wire going into the trailer plug and give it a good tug. It might have corroded inside. Try piercing the wire and seeing if there is power. Beyond that, I wouldn't spend a lot more time trying to trace the whole thing. Like @4strokeluvr111 said, I'd just run a new wire to the plug.
BTW, just a dumb question, you are checking the right prong in the plug, right? I once had a![]()
moment wiring up some lights when I was using the wrong connections in the connector. Check all the prongs.
My friend is also concerned about possible corrosion in the existing wire harness. Apparently they have a history of going bad too quickly. All the more reason to not disturb the harness and just run a wire.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
OK, so this did not go good. From the factory that wire is connected to post #1 or b+. I've did what I could do. I have remote start that is sharing same post. Which thru me cause I have power at both terminals on fuse. I assume the remote start is back feeding power for it to work.
Switch to post #2. Same. No power to rear.
Friend shows up with exact same truck. We open the hood, put 30amp fuse in and he has power to top right terminal. Where I don't.
So, it's down to chasing a problem or running a new wire.
I hate!!!!! Butchering a new wire in!!!!! But I don't see thing ending any other way!
Joe
Joe
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
With due respect Joe, I would call running a new wire far from it being a "butcher" job. Run the wires along the LS (?) side of the truck where your fuel and brake lines are. Liberal use of zip ties makes everything look clean. Remove/cut (and splice) the + wire from your existing round female connector.
I myself have done this several times and I'm anal about clean looking wiring.
Doc Harley
- Oct 17, 2016
- Here & there
I'm anal as well. I'm going from the point where, I have a perfectly good wire in a loom that is not functioning. And it's less time consuming to just run a new lead.
Well..... Obviously not a perfectly good wire! Lol. And the real problem I have is, the lead from post#1 to the 7way is direct! I'm shocked it doesn't work.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Do you have the larger square fuse in for Post #1? Is it good?
One of the leads goes to your brake controller....the other one (in the loom) is for the 7way.
Doc Harley
- Oct 17, 2016
- Here & there
None in loom! My truck and buddies today, that he has owned since new, verified. Wire was always connected, with dummy fuse in place.
Yes, I removed dummy fuse and replaced with 30amp
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
So you should have power to the 7 way now?
Doc Harley
- Oct 17, 2016
- Here & there
My friends truck has power doing the same to his, mine does not.So you should have power to the 7 way now?
I stopped by the guy who installed my remote start. He spent 20mins on it.
He says to just run a new lead to back.
So, six guys tell me to run a new lead. Lol! I'm stubborn, lol, but I've given up.
New lead it is. Do I need to put an inline fuse?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Yes you should. A HD type of fuse as well.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
As long as you're after the 30A fuse in the fuse block and your wire can handle 30A, I wouldn't bother with another inline fuse.My friends truck has power doing the same to his, mine does not.
Doc Harley
- Oct 17, 2016
- Here & there
Post #1 fuse has power coming in from both sides. No I can't explain.
Other than there's a lead going from post #1 to second battery on passenger side. (All factory)
No one has touched this truck except remote start guy. He claims it's not his wiring. I believe him.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Just run a wire from the positive on the battery (either one I guess) and use a similar kind of inline fuse as this:
http://www.mouser.com/ProductDetail...6bljE77jO7msf1e6bzzBj7RQ2qjNcNm-KxBoC2czw_wcB
A trip to any local auto parts store is all you have to do.
Doc Harley
- Oct 17, 2016
- Here & there
I got it all! 14ga wire, inline weathertight, buts w/seals, loom,
I am assuming, I'm cutting the wire at 1o'clock position on truck?
Spent the day working on trailer. Another nightmare all together.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Only 14 ga.? smh. What size fuse did you put inline?
Doc Harley
- Oct 17, 2016
- Here & there
Well, I got the assortment pack. I think 30amp is the biggest in the package.
