out-front-Y
I need some help with my new leak down tester. I know i have to bring
the cyls tdc. Ok this is what i did i put 30psi in each cly and the cylinder
leakage read 0 to 10% on all cyl . But as i move air psi around things change.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
out-front-Y said:I need some help with my new leak down tester. I know i have to bring
I think you need to put 100 psi in the cylinder but dont' know what leak tester you have.
Ted.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
on my gauge, I have to bring it to 100psi
then calibrate the gauge to read ZERO when disconnected from cyulinder (zero leakage) then read 100% when connected to cylinder and valves are opened.
On my rx1, I get from 4% to 7% on my gauge
I think below 10% is all set.
as a reference, my tpex motor (the one I had all 4 cylinders tapered and ovalized) got between 40 and 65% of leakage...
out-front-Y
Thank you !
ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
I did a leakdown on a 05 Warrior last night that has 8900 kms on it and had 2% leakage in all 4 holes . I used 90lbs air pressure.
