Has any one put led lights on there sled. Was thinking of putting them on my 06 rage.
Thanks Scott
Thanks Scott
RocketRollinSX
I've got a clear tail light on mine that I plan on swapping out the regular 1157 bulbs for LED's. Planning on tackling it this weekend, will post pics when I finish it.
Groomerdriver
Brite Lites
I put LED's from Brite Lites in the back of my o5 Vector ER. Put their brite white bulbs up front replacing the factory bulbs. MUCH BETTER!!!!
p0wd3rp1l0t
sxr-600-u plan on puttin tailights and headlights, or u plan on runnin like led lights for cars-under body lights? if ur lookin at underbody lights, check out www.snowforce.com they have some good ones, i have 3 on my rage and look pretty sweet
garserio
- Nov 30, 2004
- Fairport, NY
- 2014 SR Viper
2001 AC Z370
2006 AC F120
As appealing as LED lights sounds, don't underestimate the side benefit of a normal incandescent lighbulb... HEAT.
Believe me or not, but the heat generated by a stock lighbulb actually helps keep the lens from icing up.
Don't be surprised if your LED upgrade results in tailight icing...
trucknut
I tried the led 1157 replacements they were no were near as bright as stock?not sure why the set i put on my trailer are awsome!
Groomerdriver
no icing here
560 miles and nary a hint of icing...front or back...
garserio said:As appealing as LED lights sounds, don't underestimate the side benefit of a normal incandescent lighbulb... HEAT.
sicilien
RocketRollinSX where did you get the clear tail from ?
not looking for new headlight or tail lights. Looking for lights to light up under the sled.
MIViper
Skis
pimpedrsrage, do you still have the skis for sale? PM me if you do.
Green Lantern
sxr-600 said:not looking for new headlight or tail lights. Looking for lights to light up under the sled.
I have asked too on other threads, anyone have snowforce type pictures?
p0wd3rp1l0t
Kahlua
pimpedrsrage said:sxr-600-u plan on puttin tailights and headlights, or u plan on runnin like led lights for cars-under body lights? if ur lookin at underbody lights, check out www.snowforce.com they have some good ones, i have 3 on my rage and look pretty sweet
That snowforce.com site is coming up a snowboarding site?
