Svartstreck
Kinda new to sleds, only been running MX bikes earlier
Anyhow, I bought an RTX 40th -08 with a 144" OFT tip-up extension last week.
Went out riding, and it seemed ok... until i hit some rougher patches, which pretty much felt liks someone kicking my spine.
The previous owner had also mounted a set of different drop brackets, which has moved that position about about 2 inches down, making the sled higher in the back - just like the xtx he said.
The strange thing is when i was checking the suspension settings i saw that it's sitting on the transfer limiter blocks (the white half moon shaped thingies on the skid)
If I pick the rear up it looks alright, but when i let it back down it's pretty much free falling until it hits those blocks.
And it's not even close to being low in the back.. has the drop brackets messed up the geometry so badly that the suspension bottoms out on these blocks or something?
Sag when i put my all 210 lbs on the rear bumper is less than an inch..
Any ideas?
Thanks //Gabriel
Any ideas?
Thanks //Gabriel
It's couplng the skid as it's sitting flat because of lifting the rear causing it to be extremely stiff and more so will not tranfer any weight. I'd ditch the lift kit, we're riding sleds not mud trucks
Svartstreck
rlcofmn said:It's couplng the skid as it's sitting flat because of lifting the rear causing it to be extremely stiff and more so will not tranfer any weight. I'd ditch the lift kit, we're riding sleds not mud trucks![]()
Makes sense
Yeah, kinda sucky mod as it should have had enough clearance as it was, didn't notice it when i bought it..
Also, I didn't get the OEM mounts with it either, so I'd rather try getting it somewhat better than it is now and just live with it than putting the drill to it hehe
The limiter strap in front is pulled up to the middle holes instead of the stock position, so I'm going to move it back to where it belongs tomorrow when the blocks of ice has molten away some.
These coupling blocks, can I remove them, or do I risk damaging something in the process?
gormleyflyer2002
isnt it typical to get heavier torsion spring when ext to 144 ? your adding to the lever?
Svartstreck
gormleyflyer2002 said:isnt it typical to get heavier torsion spring when ext to 144 ? your adding to the lever?
I got no idea, have mine set up on meduim atm, seems to work fine
Removed the coupling blocks anyhow.
Other than the sled getting a bit jerky at slow speeds on trails, I like it very much.
Boondocking just got fun again!
gormleyflyer2002
i guess
i can see boondocking being fun.....who needs steering !
Svartstreck said:gormleyflyer2002 said:isnt it typical to get heavier torsion spring when ext to 144 ? your adding to the lever?
Boondocking just got fun again!![]()
If you want some stock brackets shoot me a pm, I've got a set sitting on the shop floor about to be tossed. You can have them for the cost of a flat rate box.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Swap out the primary spring that has a lower initial spring pressure to get rid of the harsh/jerky engagement.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Svartstreck.. I have the same sled as you, and I also ride in northern sweden, more than likely in the same area as you.
I installed a set of timbersled drop brackets this summer, and am really happy with it. It seems like i dont get stuck as easy as before, because of the higher clearance between the running boards and the ground.
How much rise is there with your brackets? Do you have a picture?
snomaniac
dimebag that is a killer avatar pic. Was that you being ejected, or what's the story?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Hehe, thanks. Yep, thats me being ejected
I was boondocking and the sled suddenly turned a little to hard for me to hold on too. If you look really close you'll see that the tether is still attached to the sled.
Svartstreck
Dimebag said:Svartstreck.. I have the same sled as you, and I also ride in northern sweden, more than likely in the same area as you.
Sweet =) I'm riding around in the eastern part of Jämtland, between Östersund and Sundsvall
Yeah, the height seems to be of advantage riding out here, not really any trails around, even less of them groomed - so back country it is
I have yet to get stuck by hangning it on the steps
The drop brackets adds 2 inches, might look dif in the pic, but that's just my shoddy camera work xd
Thinking of machining new all nylon limiter blocks and bolting them in the hole where the guiding pin for the OEM blocks go, so that it's still going to be somewhat as supposed to
Edited, didn't rly figure out how attachments worked the first time around!
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Nice sled.
I think my brackets are a bit taller than yours, but its difficult to see in the pictures.
Here are some pics of my brackets if you wanna compare:
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
Another thing, when are you gonna call Marklund and have him do his magic to make that thing really rip?
Svartstreck
Dimebag said:Nice sled.
Another thing, when are you gonna call Marklund and have him do his magic to make that thing really rip?![]()
Yeah yours seem a bit taller
Don't think this one is ever gonna get turbo'd, don't even need the power it's got atm around here.. neither high-speed trails or any fun mountains
Best riding around here is power lines, and a turbo isn't needed + I like to pay in cash and buying this one pretty much drained my account = no turbo xD
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
I understand.
I rode my sled one season (3000 kms) before i turboed it. Up in the mountains the turbo is nice to have. Especially to have a chance to follow my riding buddy on his mtx.
Hope you enjoy your sled, and have a nice riding season
