Limiter strap - factory position ?
Harrisburg, PA
Just looked at my track limiter straps - they are in the 4th hole up from the track - the holes nearest the shock - is that the stock position from factory for apex GT's ?
um....not sure if this will help but i lengthened my limiter strap as much as i could over stock and that was only by 1 more hole.
I thought I counted 4 holes total & stock I was in #2 hole with transfer rod to min.
OK - then I guess mine is set to one hole past stock since mine appears to be the full length. Now does that help minimize or maximize weight transfer to the rear end ?
Maximize if you want to do wheelies. I like skis planted on ground for trail riding but different set ups for different riding styles. If you are lake racing you would want the front end floating.
I have my limiter strap as far out as i can..one more hole..and transfer rod set to max, so when i play in the power i can always get my front end up like nothing, and can do wheelies really easy, and i still have plenty of ski pressure.
