WolfOne
- Apr 13, 2007
- Lake of Como - Italia
- www.qteamsas.com
Not have chance to put hands on a stock mtx till end of dec.
Could someone take 2 mesaures for me from a stock 2010 or 2011 mtx?
H: from the top of the tunnel to the center of suspension bolt
F: from the center of the suspension bolt to the ground (suspension full extended)
WolfOne
- Apr 13, 2007
- www.qteamsas.com
Up
towerrigger
Can do this as soon as I get home tonight. There are two suspension holes in drop bracket. Do you want both?
WolfOne
- Apr 13, 2007
- www.qteamsas.com
towerrigger said:Can do this as soon as I get home tonight. There are two suspension holes in drop bracket. Do you want both?
The lower to the ground could be enough
Thanks a lot man
towerrigger
I did my best using a plumb bob for center of bolt to top of tunnel and bottom of hyfax and a level for all 3 points.
Bottom bolt
center to top of tunnel = 330 mm
center to bottom of hyfax = 280 mm
There is 20 mm difference between the two bolt holes
My skid was fairly iced up when doing so, I can double check the measurement to bottom of hyfax when it thaws out. May not of been fully extended.
[/b][/u]
Bottom bolt
[/b][/u]
WolfOne
- Apr 13, 2007
- www.qteamsas.com
Thanks towerrigger, this is very helpfull for me because i can end drawing my new chassis before Christmas
