Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Hello all
I wanted to post these in a higher traffic area so that more might see
What do you think
What do you think
Snowwmax
Nice
, though I can't see those front springs /shock lasting too long
Bob Miller
- Apr 19, 2003
- New Milford CT
CraZySteve said:Nice, though I can't see those front springs /shock lasting too long
Steve what you see on that machine will go on and off in a minute or less
One thing for sure is that you can use your ATV for much more than just riding, these things are real "Work Horses" :exc:
Snowwmax
Well I am just relating this to a fullsize rig where you have a Plow mounted... you have to change the Springs in the front to accomodate the heavier weight...
I know most ATV's have a front rack weight limit of around 100 lbs.. so I guess if your attachement weight is less than that you are good.. but then again.. you attachment weight would have to be about 75lbs or less as the attachment "moment" is acting farther out, from the suspension as opposed to the front rack weight acting directly downward on the front suspension...
Sorry if I over analyzed this.. but I am an electro/mechanical engineer... just my nature
Bob Miller
- Apr 19, 2003
- New Milford CT
Steve,
When it was time to get tires on that 1986 Honda FourTrax 350 I installed a set of Buckshot Mudders (4 PLY) and they worked really well with these attachments
just pump up the pressure and it worked really well with the weight loads. Of course when your picking up something heavy the machine should be properly counter weighted and you have to use good judgement.
dillholehecker
- Nov 24, 2006
- silverthorne
- silverthorne
- AOL
- yamahaping
AGAIN yamahas whats with the kawisuckme WTF?
Bob Miller
- Apr 19, 2003
- New Milford CT
dillholehecker said:AGAIN yamahas whats with the kawisuckme WTF?
Just sharing some Idea's that work on any ATV DillHole!
The attachment on the Prarie has been used on Yamaha's, Honda's, Kawasaki's etc... etc...
dillholehecker, be nice, Bob has been around a long time on Totallyamaha.
Ganz
- Jun 5, 2004
- Deerfield Wi
- Deerfield Wi
I think those attachments are SWEET.
Nice job Bob.
Nice job Bob.
