longtracking questions
minnesota
i have a 05 121 rx1 turbo and i would like to put a longer track under it for going to the mtn's so is it possible to get a extention from 121 ( stock skid ) too 144 ( i was told you can longtrack and 121 because of the skid ) if so from who and how much are they also whats the biggest lug you can put in with the 9 tooth or 8 tooth ???
p.s
chaincase is in stock spot with stock skid
mike.j
call tracks usa. there are the best extensions and he can answer any ?'s
no extensions for the mono skid. There are aftermarket skids, or swap to a warrior skid and put extensions.
You can get a tunnel extension for it though.
Ive got a hartman extension(best looking tunnel extension I have seen) on the way for my 05 bought it from a fellow ty4stroke member,it was for an 04.If the 04 rail extension doesnt work on my 05 ive got a milling machine and TIG welder Im shure I can come up with something.I plan on machining up hyfax extensions anyhow.
I ordered the fully clipped 136" ripsaw 1.25" with quiet drive today for 375.00 shipped from tracks usa.Ill let you guys know how much difference the quiet track makes in the noise department.
Supposedly when you long track the Mono, since it has no coupling, adding length makes it act very weird. The longer you go, the skid gets soft and softer (more leverage against the shock)
I actually sold my Mono when I went to 136 and put a ProAction back in it.
