nytro addict
Thought there was a sticky on torque specs. Did my searchs and can not seem to find any for some reason.
Well I'm going to be putting in an Ulmer clutch kit on my XTX and looking for torque specs for every nut and bolt.
And if there is any other helpful hints for installing the clutch kit, please feel free to give advice.
One other ? How are the super tip weights suppose to be set up on the fingers?
T T Bone
Ask Ulmer they know. If you want check with a torgue wrench before you take the clutch apart. Remove the belt. Very easy procedure, 8mm, 10 mm sockets, 2.5 mm allen wrench. 8mm wrench and lock tight I use blue. May have forgot one tool. Good luck and you will like it.
dansranger
Its in the FAQ sticky, under the service manual.
nytro addict
dansranger said:Its in the FAQ sticky, under the service manual.
Thanks finally found it, I may need glasses being how many times I looked there...
