I was greasing the suspension tonight (Apex GT) and came across a fitting just behind the wheels in the middle of the skid and found it loose. There appeared to be no way to get a wrench on it to tighten and it still to grease. Are these fittings pressed in? The other side was tight. Is this anything to worry about?
BURMAD69
Most of the skid fittings are press fit and then spot welded.
leaddog
Try a dab of JB weld around fitting. It has worked well for hundreds of us.
04rxwarrior06
wow good thing is just read this, i was about to pull my skid out and weld it!
