lost lowbeam
srx900
oswego ny
My lowbeam on my headlights quit working. The bulbs look good, I tested the switch per the service manual and that is fine. Has anyone had a problem with the relay with only low beams.
I had one of my low beams go out last season, it would pop on once in a while. Put a new pair of Silverstars in and back in business. 2006 RTX
Bad bulb (my opinion). Did you loose low-beam on both bulbs? If not, swap one bulb for the other and give it a try.
The fillament could look good, but even the finest break will cause non/sporatic connectivity.
I'd put my $$ on bad bulb though.
--Steve (O.C.)
Do you know the part number on the silver stars?
