Tork
yammiman said:Tork - you have any part numbers on the wheels? - when you say accessory, are you refering to the inner, the outer, or both?
sure
5.320 dia. and a replacable 6205 bearing.
P # 503 190 802 like $19 ea, you can even get end caps to cover the bolt if you want.
I had all my 6 holders machined down .075 so the bearings go on further, cost me $45.
other options are longer bolts-or- to loctite on the nuts.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Tork, do you have a picture of SLP anti wear pads are on the track, so I can see what they look like. I still don't understand how they are supposed to work. Thanks....
Tork
No, didnt take a pic with them installed and sled is up at the cabin.
but I can explain them. Drill a hole right in the center of the closed window. Install them on the inside of the track like you would a push thru stud. From the outside of the track install washer and nut. The smooth flattened carrage bolt type head runs on the hyfax so the bare rubber cant drag.
Ole Timer
Do you have to replace the SLP thingies very often ? I would think they must be a high wear item. How many do you need for a 121"?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
That illustration isn't correct. The head is flat like the head of a stud not rounded like a screw or bolt.
http://www.denniskirk.com/jsp/product_c ... uId=080330
dirkdiggler
Suspended
machj said:my gt has no more pulling power or top speed can only get 114 on speedo always use to pull from 118 to 124mph tryed new belt cleaned clutches secondary set at 6 and 1 the red light doesnt come on anymore when cold maybe theres something to this any ideas
Pull your belt off start your sled and Take a piece of Scotch Bright and clean your primary.
Smoke
- Nov 13, 2003
- Fredericton, New Brunswick, Canada
Snow conditions for sure! This weekend, I started out on good trails (freshly groomed and well set up after a cold night) I saw 118mph on the DM. Later in the day after alot of traffic and softer trails, I only saw 108mph. On a hard packed plowed road I have seen 128mph, so conditions are everything.
y_guy
- Feb 22, 2005
where do these get installed? do they ride against the hyfax? (right under them)?
cameljockey
yes, centered under the hyfax.
